mustangzach812
Hello to all,
I just purchased a 97 challenger 1800. I got a good deal on it, but didnt get much info on the boats history in exchange. When i purchased the boat the passenger side motor wouldnt turn over, it sounded like the starter was bad. I could hear the starter turning but nothing other than that. I replaced the starter and the motor fired right up. I put the boat in the water for the first time friday afternoon to see how she ran. The passenger motor seemed to run very well, but the driver side was a little slugish. Once the driver side motor got to about 6000rpm, it would back off and die. The boat was also almost impossible to get on plane. I pulled the boat out and replaced the plugs and fuel filters then put it back in. It seemed to be running better but i was still having the problems with the drivers side motor. I ran the boat at about 4500rpm for about 25 minutes to see if i could get a possible fuel blockage loose. The boat ran great at this rpm. After about 35min i pushed it up to 6000rpm to see if it had fixed the problem, and the motor died again. I immediatly shut off the other motor and sat in the water for about 15 min trying to figure out what could be going on. Then when i went to start the motors back up the passenger side motor wouldnt crank and was making the same starter noise it did when i bought it. So i am lost, i limped home on the driver side motor and have tried to start the other on several times since then and still nothing other than that noise. I checked my connections on the starter and they are tight, so any help would be greatly appreciated. Also does anyone know what is going on with the drivers side motor losing it at 6000rpm, thanks in advance.
Zach Hinton
Ft. Hood, TX
Zach Hinton
Ft. Hood, TX
