So I bought a 96 gti yesterday and with it came a 96gsx that needed some work.
The guy stated he was getting a no beep no start issue and beloved it was the key post/lanyard. Upon looking at it further I knew it was more then that because the rear electrical box, and vts were taken apart, and several plugs in the front compartment were removed, but I didn't care much as I didn't pay any extra for the gsx.
Today I messed with it a bit and connected all wiring plugs that were removed.
I reattached the two individual wires that feed the vts motor as well as a plug that feeds wires that run behind the motor.
I found there was a break in the black wire that runs from negative battery post to coil, I replaced it.
I found a knick in the positive battery cable that feed start selinoid, after cutting back the insulation I found the wire was corroded half way through, so I replaced it.
I found the 5amp fuse in rear electrical box was blown, replaced that.
The 15amp fuse holder in rear box looked questionable, so I cleaned and checked continuity on that.
I verified the key post and lanyard was bad with a meter, so I replaced them.
And lastly I found the 5 amp fuse on mpen blown, so I replaced it.
Then reconnected the battery, and nothing... no start no beeps.
It did blow the 5 amp fuse in rear electrical box again. I checked with my meter abd was getting 12 volts across the fuse( meter probe on each side of fuse holder) so I tried removing the wires from the vts again along with the wiring plug that feeds wires that run behind it, and with those wires removed. The fuse does not blow. But still dosnt help my starting issue.
If i jump the selinoid the motor will turn over.
I guess my questions would be.
1. Is that 5 amp fuse in fact for the vts system. It got dark before I could start chasing the wires. If so, how could I be gettoing 12 volt across the fuse block.
2. Those wires being disconnected shouldn't have anything to do with to no start no beep issue, right?
3. I've researched the issue and people say to verify you're getting power to the mpen, which wires should I be checking for power?
4. I've also read I should verify the mpen had a good ground by running a cable from the mpen and grounding it to the motor. Which wire should I be grounding?
Any other ideas to point me in the right direction?
