I picked up a 2002 gtx for free. All I know about it is it has been sitting for a year and a half and nobody has done anything to it. I'm thinking I need to try and turn the engine over by hand before trying to start it just to get things moving. I want to make sure it's not locked up before putting any money into it. (Have to buy keys and batteries)
How do I get the engine to turn over by hand? I tried to see if I could use the drive shaft that comes out of the back of the motor, but there is a rubber cover around the only section of shaft I can see in the hull. I tried to take cover off, but it doesn't appear to come off unless you can take it off the end of the shaft. Any help on how I should turn the engine over? Is there a timing plug that I can pull off to access the crank to turn it over? Any other things I should look for before getting too deep into this?
I have a lot of experience with Fourwheeler's and dirt bikes, but this will be my first seadoo project.
