I have a 96 GTX with a 787. I've pretty much rebuilt everything from the engine to the jet pump, including the carbs. The carbs will pump fuel and both of them pop off around 26-27 PSI. It seems as if the carbs will not let fuel past the needle when I have them on and trying to crank it. When I take the carbs off, there is no fuel in the fuel chamber. I feel like I've tried everything prior to posting a thread but at this point I'm not sure what to try next. When I rebuilt the carbs, I sprayed all the ports and jets with carb spray to clean them out. Any suggestions would be greatly appreciated!
