Hey Guys, I'm new to Seadoos and don't have much two stoke experience so any help would be greatly appreciated. Excuse my ignorance if I use incorrect terms etc. Last year I had my Seadoo SPX 650 out and battery went dead. Im unfamiliar with waverunners, towed it in with my boat too fast and sunk it. I pulled the plugs, shot all the water out, put new plugs in and got it fired up but it was really rough and would die when I gave it gas (assuming gas was contaminated). It was the end of the season so I pulled the ski out, cranked on it to get all the water out, stabilized fuel and pulled plugs and sprayed fogger in the cylinders and stored for the winter.
This year, the engine is seized up. Replaced starter and battery. The PTO and the impeller move when I click the starter. They move very little, about 1/8 of an inch per click but will keep moving as long as I click and spin all the way around. Tried spraying some more Oil fogger in but can't move the PTO by hand or pipe wrench. I also noticed I had a rope wrapped up on the shaft going to the impeller that I cut away.
What's my next step? I'd rather not pull the head off but that may be where I'm at. Is it possible it is the Jet Pump? I know how to take that off but how do I tell if it's bad? Thanks for the help!
