A.J.C.
Hey guys, I have not posted on here since the summer since I finished replacing the engine in my 1997 Seadoo Challenger. When looking for odd hard to find parts for my boat, I stumbled upon a shop that was closing and wanted to sell all their seadoo parts as a large lot. Although I only needed a few odds and ends, the shop would only sell as a whole package so I bit the bullet and bought everything they had. All the parts are still packaged with parts numbers but I really have no idea what I have. I can start posting pictures and part numbers if anyone would be interested. I'm willing to sell what I don't need to recoup some of my money. I have hundreds of parts so it will be quite a bit of work to list everything with pictures but if there is interest, I'm willing to do it. Otherwise these parts will just sit and collect dust.
They are all genuine new old stock seadoo parts.
Let me know if anyone is interested or something you may need and I will see if I can sift through it all.
Thanks!
Here is a partial list. I still have 292xxxxxx - 400xxxxxx Parts numbers to list.
The prices are list prices, for my reference, not what I am asking.
Seadoo Inventory List
250000018 Screw Pivot
250000023 Screw Pivot
269000415 Purple Corner RH- Seat - $7.07
269500530 Latch- Discontinued
269500577 OBS Support- Gauge - $9.97
269501125 Latch- Discontinued
269501487 Latch- Discontinued
269700016 Lever Latch- Discontinued
269700022111 Hinge RH- 29.99
270000114 Gasket- Discontinued
270000149 Cable Guide Discontinued
270500017 O-ring $2.47
270500046 Gasket- $4.99
270500056 Spring Release ?
270500119 O-ring $6.99
270500123 VIS Screw $7.99
270500127 O-ring
270500138 Pump Cover $44.99
270500155 VIS Round Screw $6.99
271000040 OBS Sleeve $12.95
271000055 Impeller Boot $3.47
271000114 Trim Protector Boot $11.95
271000122 Sleeve $8.99
271000212 Bushing Plast $8.99
271000305 Impeller Boot $3.47
271000313 OBS Ring $9.99
271100338 Tube Siphon Discontinued
271000659 5.5m Spacer ?
271000704 Spring $5.99
271000466 Pump Grate $84.99
271000973 Spring $5.99
271000108 Spring ?
271001133 Tube Siphon $5.99
272000051 Washer- FIXAT $10.99
273000006 Clip Retainer $6.99
275500035 OBS Packing $2.49
275000081 OBS Oil Cap Assy $21.99
275500153 Fuel Cap Black- Discontinued
275500173 Fuel Cap Pink- Discontinued
275500111 ADAP-Tube- Fuel $7.47
277000038 Boot Small $5.99
277000039 Boot Large $6.99
277000106 Support Rear $37.49
277000166 Thrust Arm Discontinued
277000203 Cap-Grip Black $6.99
277000206 Cap-Grip Pink Discontinued
277000277 Boot- Large $6.99
277000381 Pin $1.82
277000466 Boot Small Discontinued
277000473 Boot Large ?
277000144 Accelerat Cable- Throttle $61.47
277000098 Accelerat Cable- Throttle $123.47
277000077 Choke Cable $76.99
277000783 Half Ring Discontinued
277001018 Tube Seal Discontinued
278000058 Brush Holder Discontinued
278000099 Nut Safety Switch $6.99
278000129 Safety Switch with wiring ?
278000295 Relay Module ?
278000631 Terminal Male $2.99
278000636 Wedge 4-ways $2.99
278000737 Wedge 6-ways $2.99
270000970 Sensor- Speed Discontinued
278001105 Washer Flat $2.99
278001268 Sparkplug Wires Discontinued
420965030 Ignition Cable $32.47
278002050 Knock Sensor ADA $44.99
290430200 O-ring $2.99
290830905 Gasket Discontinued
290830906 Gasket Discontinued
290831952 Oil Seal Discontinued
290832533 Ball Bearing Discontinued
290832550 Needle Bearing Discontiuned
290837392 Pump Shaft-Oil Discontinued
290926060 Retaining Shim Discontinued
290926070 Retaining Ring Discontinued
291000165 Latch Cover Discontinued
291000166 Support Latch $6.99
291000220 Corner-Bumpers Black $14.99
291000279 Plug Black $4.99
291000421 Plug Bumper Discontinued
291001040 Bumper plug Discontinued
291000457 Choke Plate $5.99
291000494 Nose Bumper $43.99
291001101 Latch Stud $2.32
Thanks!
270500127 O-ring
271000108 Spring ?
277000381 Pin $1.82
