seadoo/skidoo
If someone could help me out with a couple questions i have that would be great. i had it in the water a couple days ago and it runs great the guy i bought it off of rebuilt the motor and the compression is 150 both cylinders but once you shut it off it doesn't like to start back up easily unless you feather the throttle. the carbs do seem like they need rebuilds but i have a feeling thats not the problem. im almost certain it needs RV shaft seels so my question is could the crank case be getting flooded with oil once i shut it off therefore making it hard to start because theres to much oil in the case? it seems to foul plugs alot and for the first 5 mins of running it in the water you see lots of smoke but after that it goes away. also when there is 2 people on it, it almost never starts for some reason? so if anyone could answer why this is happening that would be great thanks :thumbsup:
