peanut8474
I didnt know what I was doing and ran the garden hose after I shut the motor off and got water in the motor and pulled the plugs and cranked it over and did this till I think all water was out and put wd40 and cranked over and ran fine and then took it to the local dealer and had a compression test and had 160 in each cylinder and took it to the lake and it ran fine for about 5 minutes and then just died like it locked up and brought it home and pulled plugs thinking I had more water in the engine but the plugs were dry and white on top and will not crank like it is locked up and I pulled the hose off the oil bottom side of the oil filter and oil ran out like it was full and possibly working properly plus I had added a litttle bit of oil to the gas to try and be safe but probably not enough oil in the gas to actually be safe. What might have happened and is there a way to check to see if it is locked up without taking apart the motor anything to look for would be greatly appreciated. I just bought it off my 60 year old neighbor and is a 2004 gti le RFI with 43 hours and that was the first time out
