Jparadise81
So I picked up a running 94sp, non-running 96xp and double trailer with diamond plate tool box for $600. The running ski has new fuel lines and a rebuilt carb. It runs good, but I think the wear ring needs replacing. The xp has an elcetrical issue, lost key and trashed gas tank. I'm hoping the motor is good...it turns when I jump the starter to the battery. The owner went ahead and bought a new key, I just need to get it programmed and the local dealer is replacing the gas tank under the service call...I think they are going to prpogram the key for me for free as well. Im cleaning the RAVES, rebuilding the carbs, changing the fuel lines and went ahead and converted both to premix...which is just my preference. I pulled the mpem and the rear of it had a nickel sized spot that was melted through, so Im assuming it was bad. I went ahead and got a new oem one so Im hoping that will fix the electrical issue.
The cover to the VTS is missing and the motor is rusted and corroded, which ive read can cause the mpem to fry, so can I just disconnect the wires to the VTS or leave the fuse in the rear electrical box out? If I do this will the ski still fire up..assuming everything else is good? Im afraid of frying the new MPEM!
The owner tore apart the rear electrical box and the ignition coil is missing. I have one on order. But I have no clue how to wire that box properly. Does anyone have a wiring diagram? The last pages of the manual I have do not have a wiring diagram. Also, there's a male 2 prong plug in that rear box that I cant find where it hooks to, does anyone know?
Thanks for all the help!
