low voltage light comes on and RFI dies
jhartal
Low voltage light on RFI comes on after short rides; followed by limp home mode.
Eventually the unit dies altogether.
At that point the battery has run donw indicating that I was running on battery with no charging system. Recharge of battery will getr me going again only to die after it runs down.
Is there a "most likely" place that I might be losing charging power. i canot really think that my 2002 magneto is shot.
All fuses are fine, and connections appear OK.
I was told to look at the voltage regulator but do not see that on the parts diagrams.
Any ideas?
Jim in Alabama
Most likely is the rectifier. I replied to your post in the other thread with slightly more details, but you'll need to test to make sure then you can pick up a new one on ebay.
