I have a question on adjusting the Low Speed Adjustment screw on a Mikuni 38BN for my two 94 GTS carbs. When pulling the carb on one of the GTSs to check the internal filter, I moved the adjustment for the LSA screw when removing the nut securing the carb to the manifold. I have a manual and reset the screw to the initial setting, checked the idle in the water and set the idle speed to spec and then set the LSA.
My question is how can I determine if I set the adjustment too lean? It does not appear to be running rich and seems smooth, but I wonder if it's set too lean. How can I check/confirm?
Thanks!
Rich
Thanks!
Rich
