Hallelujah, Hallelujah, Praise the Lord!! It is resolved!!! Well the weather was poor today as forecasted so I took the Doo off of the jet slide dock and put it on the trailer. Checked the a-pump nozzles. Checked the MAG carb nozzle first as I recalled this one had an issue last time which I thought I had fixed. Sure enough, it was not spraying gas. PTO carb nozzle was spraying great. So I removed the charge line from the nipple on the MAG carb and tried spraying WD-40. No WD-40 would pass through the nozzles. So then I blue (painters) tapped paper towels all around the nipples and covering the carb body and attempted to spray small burst of carb cleaner through. I had a small rag in the throttle body to catch anything No penetration on the 1st blast, but the second blast penetrated and sprayed out of the nozzle. I then sent several blasts of compressed air through it. Did the WD-40 spay tes again and was getting good WD-40 blasts through the nozzles. Before connecting the charge line back to the nipple, I squeezed the throttle to make sure gas was coming through the charge line and check valve. Gas pumped out of the line so I re-connected the charge line to the nipple and retested everything. Yeah!! both nozzles were pumping great streams. After some more general inspections of little items while I had it on the trailer, I put everything back together and put it back in the water. Boom!!! no more issue coming off of idle. I hit the throttle now and she pops on top of the water like a new machine.
Thanks for everyones input!! That is why I like this forum so much. I only hope I can pass along help to others when I can. Thanks again everyone!!!
