Challenger!....
I bet you do....!.......I love my challenger, but sometimes I wish I had the speedster or any other twin engine model, so that way, if one engine goes down, I'll have a back up to get me home!.........:rofl:
Be careful throttling up if you have an engine go dead. If your dragging a motor and going to fast, you can suck water into your engine through the exhaust system filling up. If your running and one engine is stalled, pinch your water inlet supply to the motor, to keep that from happening.
To test the compression, you'll take off your plug wires, put them on your grounding tab. Then, remove the spark plugs. Thread the compression gage into one of your cylinders and roll the engine over several revolutions. Record (or remember) the reading. Then do it again, 3 or 4 times to each cylinder, then get the average. You don't want any results below 100 psi and you shouldn't get much more than a 5-10 psi difference between cylinders, per engine.
Don't forget to post your results and once you do this, it's a good idea to do it once a season to keep an eye on the wear and tear on your motors.
When your done with the compression tests, if both engines come out good, then move on to checking your fuel system. Filters, inside and outsid the carbs.......
