new problem
okay, so my engine is seized as well. i just pulled it this morning to get to the starter and such, and when i tried to turn the pto, it won't move, and so when i pulled the cylinder heads off, the pistons were black. so, i was thinking, since this engine probably has more than a 1000 hours on it (so old it doesn't even have any kinda measuring meter like the new ones do), what kind of engines fit on the engine mounts for a 1990 sp? will a new engine fit into the same rubber engine mounts? or, because it's a different engine type, it has different mounts. because, if it will fit, i'll find a new one with wayyy less hours on it rather than completely rebuild the entire engine, because i'm not sure how likely it will be to find a piston rebuild kit for a 19 year old jetski.
