Good job!
Now you know that fuse did have a purpose initially right?
It would be a good idea to install another fuse in line with the wiring harness. Just in case something went wrong in the gauge and power found its way back to the tank boom....
I usually add another inline when fixing these just for safety due to its location.
I added the in line fuse and it changed the resistance reading by 8.8 k. Is this gonna change the fuel level reading[emoji848]?
Based on the fact that the fuel gauge works off the resistance system, it will make a change.
I'd drain the tank and see where the huge is and then fill it up. This will show you your two extremes.
I can find the transistor fuse on the little fuse site but where do I get it from. I am putting the ski back together in the next few days and want to put the right fuse inAcording to "littlefuse" the 5x20 glass fuses can have several ohms of resistance when going below 1 amp rating.
I would use an inline soldered fuse. I'm trying to find a part number that would work. The ones i used look like resistors.
Sonething like this should work as a direct replacement.
They claim low internal reaiatance.
http://canada.newark.com/littelfuse-wickmann/37002500410/fuse-pcb-250ma-250v-fast-acting/dp/67K1826?CAGPSPN=pla&CATCI=pla-41477300408&gclid=Cj0KEQjw3s6-BRC3kKL_86XDvq4BEiQAAUqtZ8eINTLNPoK1CN8L9bCTX3nyg1q7lNc_9MxVT6pRnCYaAkE48P8HAQ&CAAGID=35202164932&mckv=sLFI6shKq_dm|pcrid|96621768772|plid||kword||match|&CAWELAID=120185770000405342
What happened when you tried it with the 8 ohms added ?
Or with and without the fuse. How did the gauge react?
Try getting the gauge to move half way to full with the fuse and then see how much it moves without the fuse.
That should be fine. That system runs on 5v anyway.
which ones ?
