Is there a place to find definitions of all the shortened terms :IBR, MEMP ect?
Kind of, but not a comprehensive list I would think. I'll start a list that we can add to. If it gets good enough, we will "sticky" it.
Here are a few.
Brap – Brap
B.U.D.S – BRP Utility and Diagnostic Software.
CPS - Crankshaft Position Sensor
CS - Carbons seal
ECM – Electronic Control Module
IBR - Intelligent Brake and Reverse
IC - Intercooler
KS - Knock Sensor
MAPS - Manifold Air Pressure
MATS - Manifold Air Temperature Sensor
MPEM Multi-Purpose Electronics Module (Brain)
NOS - New Old Stock
OEM – Original Equipment Manufacture
OPAS - Off Power Assisted Steering.
OP - Original Poster
P/N - Part Number
PTO - Power Takeoff Cover
PO - Previous Owner
RPM - Revolutions Per Minute
SC - Super Charger
SHIT - Ship High In Transit
SCOM - Speed Control Override Module.
TPS - Throttle Position Sensor
T.O.P.S - Tips Over Protection System
TDC - Top Dead Center
VTS – Variable Trim System
WOT - Wide Open Throttle
Also muttered when your last stainless bolt disappears under the engine.
Some of these I know, some not.
RPM - revolutions per minute
CPS crankshaft position sensor
KS - knock sensor
TDC - top dead center
B.U.D.S.
ECM
TPS - throttle position sensor
MAPS - manifold air pressure
MATS - manifold temperature sensor
VTS connector
P/N - part Number\
PTO - power takeoff cover that accepts driveshaft and SC and contains rear oil pump and supports the water pump
SCOM
Thanks once again to all of you for your help. I would be lost without you folks. Tom
KS - knock sensor
B.U.D.S.
ECM
VTS connector
P/N - part Number\
SCOM
buds - BRP Utility and Diagnostic Software
ecm - engine control module
BRP - Bombardier Recreational Products.
CYA - Cover Your Ass. When referring to warranty work.
VTS - Variable Trim System.
lol @ brap,
yes its kinda sorta a 2 stroke thing, but technically if we're being accurate I guess it means hit the throttle or rev it up?
as in: brap it a couple of times to clear the waterbox?
[MENTION=43374]Coastiejoe[/MENTION]
OP - Original Poster (or Originating Poster)
PO - Previous Owner (not to be confused with PO'd, which is the feeling after muttering SHIT when the last stainless (as [MENTION=69499]Tytan[/MENTION] says) or your 10mm open end wrench slides out of sight)
-Dave
Back/Front of the owners manual aka (also known as-lol) Last Resort Book. And Shop Manual.
I have seen these abb here.
AKA
ABB
POS - after losing the wrench under the engine
TDC top dead center
BTDC before top dead center
NTSB - who you will be talking to if you hit a cruse ship.
