seadoo@19072
I have a ‘94 Seadoo GTX 650. It run great.....except the speed surges up on its own when cruising about three quarter throttle. The back story is, I was having a problem with the engine suddenly shutting down when running at full throttle, but that is a different story. As a result of trying to solve that problem, I first replaced all of the Tempo fuel hoses. I removed and rebuilt the carburetors. I removed and cleaned the gas tank and fuel switch and checked the rectifier. Once I discovered the actual problem and fixed it, I doubted my carb rebuild skill and so I decided to have the carburetors rebuilt AGAIN. But this time by a technician at a local PWC repair shop. I launched and ran the Seadoo and successfully ran it through the break in period. When I hit the throttle it took off like a rocket and the stalled out. It restarted and took off but stalled out again. On the restart, I eased the throttle on and gradually went up to full throttle. It ran awhile but then shut down again. On the next restart, I eased on the throttle and then slowly ran it up to about three quarter throttle. It ran for 30 - 40 miles at that speed.......except, it didn’t shut down. Instead it would speed up on its own. After a couple of runs, it continues to react the same way. I strongly suspect that it is the carburetors. I just read the post (The Seadoo Carb Rebuild Thread by Mikidymac, April 11, 2018) and with his instructions, I feel confident that I can rebuild the carburetors. But before I do I would like some Input to determine if I actually need to go through the effort and expense of rebuilding the carburetors for the third time in less than a couple days of running time. Is it just an adjustment that is needed or a complete rebuild? Thanks for any advise.
