I'm having trouble with the fuse block in the storage compartment in the front console. (2000 Challenger 2000). There are two fuse blocks built in on the MPEM. The port side block works fine. The starboard side block has a short (the wiring to and from the block has a short - not the block itself).
This block of fuses holds the leads for the horn, running lights, deck lights, bilge pump and blower. I was able to connect all of this to the other fuse block (losing my 12v cigarette lighters to fit everything).
We went through a series of tests and determined the MPEM was losing 3 or 4 volts on the faulty fuse block side. I replaced the MPEM and now there is always a solid 12v coming off each lead. HOWEVER, none of the accessories work (even theough there is enough voltage) because, apparently, this set of fuses is controlled by the ignition switch. Once the key is turned, the accessories come on (if their respective switch is on).
I pulled the cap ooff one of the plastic terminals which connect all of the ground wires. This un-shorted something. The accessories worked from the suspect fuse terminal. Bounced the boat around on the trailer and it shorted again.
I'm trying my patience tracing all the wires. I've tried to track down a wiring diagram to help with the problem. I can't find one anywhere.
Where can I find a diagram? Any suggestions on testing?
Thank you!
Thank you!
