jforest
I took the ski to the lake today and got it idling in the water. When I increased the throttle, the engine died. After getting home and doing some searching, I came across some people testing their ignition coils for this. So I did. I did the test on the spark plug wires for the secondary winding and it was in range with the manual. The manual said 9K-15K, it was reading somewhere around 12.5K. I did an Ohm test across the primary terminals and got a reading of about 1.1 Ohms. The manual says 0.34-0.62 ohms for this test. I know that mine is out of range but I wanted to get some input before I purchase a new ignition coil.
The ski seems to be burning alot of oil and there seems to be residue on the spark plug after running it. I put a 40:1 premix in the gas tank until the oil injection system primed after a rebuild. Now the oil injection system is primed and I also pumped some of the premix out of the gas tank and put fresh gas in the tank to dilute the premix. I feel like even with this, the engine should still run when I give it throttle.
I have rebuilt the carbs. They have a pop-off pressure of 30 PSI. Any suggestions would be great! I have a feeling I'll need to purchase a new ignition coil but I want to make sure before I purchase it.
Thanks in advance!
Thanks in advance!
