I have a 1997 GTX. I just finished putting brand new raves on it and went out for a long ride Saturday.
Power Issue: I'm pleased with the hole shot as it jumps right out of the water. However I am experiencing an intermitent power, mph, rpm issue. Upon starting the machine and pinning the throttle I get a max of 7,000 RPMs and 54 mph. If I slow the machine down and throttle back up I only get 6,500 RPMs and 48 mph. It will not return to the higher rpm unless I shut it off for a while and even then it doesn't always go back up. Could this be a spark plug problem, rave problem?
Ignition Issue: This is really the biggest concern as the machine will shut off on its own for no apparent reason. This usually happens at full throttle but not all the time. I have checked the key and it seems to fit properly. I also wiggle the key around while I'm running and it does not cause any problems. Whenever it shuts down I am able to remove the key, replace it and start up again. I can be in rough water or silky smooth water and it doesn't seem to matter, it cuts out whenever it wants to.
Any help on both of the above issues would be greatly appreciated.
Thanks.
Keith
Thanks.
Keith
