mkov608
Sea-Doo mechanics, I need your help.
I recently purchased a pair of 2002 GTX 4-tecs. Both skis had 43 hours, both have new batteries, and were recently serviced by a dealer in AZ. Ski 1 is in perfect shape with no problems; it’s a screamer! Ski 2 is a different story.
The main issue is that ski 2 only hits about 6400 RMP, while ski 1 hits 7200+. As you might expect, there is a difference in top end speed, and ski 1 jumps out of the hole much more aggressively. There is also an idle speed difference between the 2 skis. Ski 1 idles at about 2000, and ski 2 idles at 1600-1700. According the on-line Sea-Doo manual, the ECU sets the idle speed, so I’m not sure how to fix that problem.
I’ve also inspected the jet pumps and drive shafts. On ski 1, everything looks good, but on ski 2, there is a ¼ gap between the end of the drive shaft and the impeller. I’m not sure if this is a problem.
Ski 2 maintenance to date:
1. Replaced throttle cable, and reset TPS w/ Candoo
2. Fresh spark plugs
3. New battery
4. Sea-Foamed engine, and added 1 can of Seafoam engine treatment to gas tank. The skis were sitting for a while, but I’ve already run a tank of gas through it.
5. New information center (old one had significant corrosion on elect connections inside and kept setting faults)
6. Compression ck: Cyl 1= 190, Cyl 2=195, Cyl 3=195
7. Fuel pump pressure ck = 44 psi.
8. Jet pump wear ring inspection; impeller looks great, gap is within tolerance.
At this point I’m leaning toward the throttle body, the jet pump (binding) or both.
If you have fixed a similar problem, or you have other suggestion for things I should check. I’d really appreciate your input.
Thanks!
Mark
3. New battery
Thanks!
Mark
