Had the motor been stopped at the first moment the rocks were sucked in and you were towed back in, you may have been able to dislodge the rocks from the intake side with a long bent pry bar, without severly scoring the wear ring. ( I remove the plugs so I can rotate the prop) . Or, you may have to remove the pump, pull out the rocks, and the wear ring may still be intact. If not, you can save some money and take the pump to dealer ( etc) , to have them replace the wear ring, ( this will save you buying the prop removeal tool). With that much horse power, usually, the prop will spin and gouge and tear the wear ring.
