2015 RXP-X 260 Turns but won’t start
DannMeli98
Purchased the ski 4 months ago and the oil was mint and owner turned it on first try. Only issue was the owner did a water test and let the water run without the engine on for a solid minute or so. After taking her home we completely forgot to drain the water. We garage stored it for 3 months and disconnected the battery. We tried firing her up and realized there was a whole bunch of water sitting so it took a few tries but she fired up and all the water came draining out.
There was some water in the sparks and oil, so we are working on flushing the oil 2-3 times. We sucked out the water in the spark cylinders and flushed the old gas out with fresh 92 octane and we also just replaced the sparks.
Now that the fresh oil is in and old oil is pumped out the ski will crank but won’t fire up. The engine light comes on but it won’t seem to display the code after pressing set 5 times.
Any clue what the problem can be and what else can I troubleshoot to get it fired up again?
I forgot to mention, the sparks are getting wet with unburnt gasoline now. There isn’t any Water now just gas
