I need some pictures
wjd03
Hey all, I have searched all I know how to looking for carb gas and oil line connections. I picture is worth a thousand manuals, as my shop manual does'nt show throttle and fuel like connections. Can anyone poast some pics of their 89 or 90 engine with different angels?
Thanks,
re
OK, so no-one wants to send any pics....I figured it out myself....hahaha
:hurray: It does run, with gas into the carbs, I am going to clean the jets and hope it does the trick, if not buy a rebuild kit! Can you believe it? a 1989 seadoo that fires right up!
Man, I am stoked! I hAVE found that the previous owner was running the gas and fuel mixed. Anyone know what the mixture should be? 50/1....100/1 ?
40/1, or 50/1. Replace yuor grey fuel lines, and clean out your fuel selector switch(on/off/reserve), and "clean/overhaul" your carbs. No need to "rebuild" them if they dont need it.
Pix...
Thanks,
Maybe you didn't get a response because no-one else out here has a running 89 model ski....:rofl:
Wow, you dont' see many of them around. There are pix in the forum though. I'm not sure exactly what your asking but it seems you wanted to know where all the lines went to.
I did see you solved your problems though. Sorry you didn't get a response.
I think you're right
I did not consider that seadoosnipe, I guess when you get a new toy to work on, ya get hesitant to turn the wrenches and hook up lines....just want to be exact on where you connect things. But make no mistake, I read just about everything in these threads to learn stuff about my new toy. I will be a regular here, and perhaps I will be able to help others in the future.Thanks!:hurray:
