Hydroturf, steering wheel and nav lights
apettit7
2009 Speedster 150 NA. I put in black molded-diamond hydroturf, new steering wheel, and some LED navigation lights. In the pictures the navigation lights are not permanently wired in yet - I wanted to see how they held up with a day in the water before I drilled any holes. During the off-season I'm hoping to upgrade the stereo and speakers, put in two batteries and a few other things here and there.
Check the regulations for the areas you boat in before you install those lights. I know here in Australia they would not be allowed because they can be seen beyond the maximum allowable angle which can then confuse other boaties in relation to the direction you are heading.
I agree on those port/starboard lights, they don't look legal to me. I once received a ticket for no mufflers in my headers, it coast almost as much as the headers cost. I was on the water testing them for maybe 30 minutes, he heard me coming and was on me like drone on ISIS.
I was told by the county sheriff water patrol boat that as long as I still used the original lights I was OK. Most likely I will end up removing them anyways as I'm iffy about having electrical wires on the outside of the boat.
Yes. My interpretation of uniform maritime law is no other external lights aside from approved nav light are allowed while underway. I believe this includes use of a spotlight even b/c it can confuse other boaters.
Probably you won't be ticketed I guess but if an accident was to occur it might and a degree of complexity to the circumstances.
I agree, especially a spotlight as the stern light on any vessel is white, a spotlight could be confused for a stern light and than can cause a whole mess of trouble. I think your country sheriff is incorrect as the led colours are the same colour as the nav lights and can cause some potentially expensive and dangerous confusion.
Very nice. Was the Hydro-Turf easy to install? Any tips?? I just bought a 2002 Utopia 205 and ordered the Hydro-Turf kit for it.
Yup, hydro turf was an easy install assuming the surface is clean. We did it on a sunny day in the driveway and was sure to layout all the pieces and put weight on them to take some of the curl out. Many summers later, it's still holding up well!
I love the wheel as well. Mine is starting to crack and wear. I was going to put a cover on it, but that one is sweet! Is the old one tough to figure out how to take off? I have never even looked at it assuming I was going to put cover on.
Good work!
I really like the steering wheel! Where did you get that?
The wheel is a car racing wheel from eBay - search for racing wheels in automotive. I paid somewhere around $30
the hub adapter that came with the wheel was for a Nissan so I bought a marine hub adapter from Grant - $25
http://grantproducts.com/products/browse/installation-kits/marine/
Grant also sells steering wheels
The bolts to mount the new wheel were very dull looking so I bought some shiny bolts from the local hardware store - $5 bucks or so
removing the original wheel was mostly just a few screws on the back of the wheel holding the cover on, remove the steering nut, and a lot of grunting and tugging.
The new wheel is a smaller diameter and takes some getting used to out on the water.
2002 SeaDoo Utopia 205 - New Stereo, Speakers, Amps, Sub Woofer, Hydro-Turf installed
New Stereo, Speakers, Amps, Sub Woofer and Hydro-Turf installed.
I'm joining this thread a bit late,,,
First, the steering wheel is a very nice match. Well done on that.
Your lights WILL get you a ticket. Even in the event where another boat was to hit you, you would be wrong. All the lights come back to the magic number of 360 Degrees. A masthead light is 225, the stern light is 132. Add the two up and you get 360. Side lights are 112.5. Add both side lights and the stern and you get 360.
I did 23 years in the Coast Guard and light issues are dealt with pretty seriously. I can't tell you how many deaths I dealt with that came back to no lights or improper light configuration.
The rules cover Intensity, arc, stopping points (often done by the bracket it is housed in), mounting location, and up and down visibility..
Here is a cut and paste that will make things very clear.
Sidelights that meet the rules are designed to cover an arc of the horizon, or sector, of 112.5 degrees. Intensities are required to attain a visible range of 1 mile for vessels less than 12 meters (39.4 ft.) and 2 miles for vessels 12 meters or longer. These fixtures are designed for intensities to decrease and reach practical cutoff between 1 and 3 degrees outside their prescribed sector. Sidelight fixtures must be installed parallel with the fore and aft centerline of the vessel and arranged to show an unbroken light from right ahead to 22.5 degrees abaft the beam, a total sector arc of 112.5 degrees.
Sidelights that are installed in the contour of the bow without providing a mounting surface tooled to be parallel with the fore and aft centerline of the vessel are not in compliance with the Inland or International Navigation Rules. Depending on the breadth of the vessel near the bow and how far aft from the vessel's stem the lights are mounted, this shift can be more than 20 degrees in some cases. Installing the fixtures too far aft of the vessel's stem may result in the sidelights not being visible from a position dead ahead.
Another factor in proper installation of sidelights is that they must maintain their required minimum intensity in a vertical sector from 5 degrees above to 5 degrees below the horizontal. They must also maintain at least 60 percent of their minimum required intensity from 7.5 degrees above to 7.5 degrees below the horizontal. Installing flush mounted sidelights, designed to be mounted to a vertical surface in the hull contour, without providing a mounting surface tooled to be vertical, shifts the vertical coverage sector. This also results in a noncompliance with the Inland or International Navigation Rules.
Additionally, most of these flush mounted sidelights are installed below the vessel's rub rail. International Navigation Rules require that sidelights be installed above the uppermost continuous deck. Therefore this configuration would not be in compliance with International Navigation Rules
