how to fine tune twin carbs on a 94 xp
joe102951
hello how do fine tune twin carbs on a 1994 cp witha a 657 ROOOOtax
can you get it to run smooth with engine knocking at idle? And is there a way to make it shoot out of the hole faster?
You engine shouldn't knock at idle. The Low Speed should be at 2 1/2 turns and "0" adjust for the High speed screw. Fine tune from there. Be sure both carbs are in sync.
Karl
ok so it should knock ... where is the highspeed adjust and the low speed adjust located all i see is 1 adjust for idle for both an on the outsides of each carb theres a lil dial to turn i dont anything else maybe a pic would be better to explain it all get 1
