how do I pull the pump and check the grease, What other maintenance should I be doing
3pedalmini
I have a 2011 GTI 130 with 39 hours and im also picking up a 12 GTR215 on friday 0 hours :D Im getting the GTI ready for the season and i feel like i should be checking other things rather then just "de-winterizing" it. I see fellow PWC owners talking about pulling their pump and checking the grease. How do i do this?
What else should I be checking/doing?
I should also note that im changing the oil with amsoil and changing the filter & plugs
Thanks Guys :thumbsup:
stick with BRP oil there are no other oils made which have the addictive it has it might be fine in a 155 hp engine but IMHO opinion did not use it some dealers will not honor wty. and did not use it in a 215 hp engine. your pump should be fine for 100 hrs , check wear ring if it's ok run it, when you service the pump it needs to be completely disassembled and packed , get a shop service manual if you are going to diy
No reason to pull the pump at those hrs unless you sucked up any debris and damaged the wear ring or impeller.
