My 96 GTX has a speedo problem as well. I have the manual, but am confused on how to test the sensor.
"Speed Sensor
To check if the speed sensor is operational, disconnect
the speed sensor connector housing
from inside bilge.
Using an appropriate terminal remover, remove
the PURPLE / YELLOW and BLACK / ORANGE
wires from the tab housing.
Reconnect the PURPLE / YELLOW and BLACK /
ORANGE wires in the receptacle housing.
Connect the positive probe of a voltmeter to
speed sensor PURPLE / YELLOW wire and the
negative probe to speed sensor BLACK / ORANGE
wire.
Depress the start / stop button to activate the delay
timer.
Spin the paddle wheel. There should be a voltage
fluctuation."
Are you actually pulling the pins out of the connector for this test? Anyone done it that can translate the above directions?
If the sensor is bad, is it serviceable (hacked) or is it just a replace? Mine is intermittent. Sometimes it works at higher speeds, other times it does not.
