Do you know how many tests they performed? If I saw that, I would pull the plugs and discconect injectors and coils and turn the engine over to see if any fogging oil etc came out of the cylinder that's high. If you see the same numbers after 3 consecutive tests and that cylinder came back at 180 you have a problem. Was the engine recently rebuilt? If so, they may not have machined (decked) the cylinder head or possibly re-used the cylinder head gasket.
If I were you I would just pull the plugs spin the engine and try comp test again, if numbers are the same find another boat. My $0.02
