Turbonator
I just bought a 1997 SPX (basically a 96 XP) and when I saw it it fired right up, and ran nice and smooth. Then, when I got home and put it in the water it also started right up but it would never really go any faster than just a bit past idle speed. Had this sound where every now and then it would do a loud POP POP sound like it was about to come back to life and go full send, but it never did. So my line of thinking is the carbs sat for too long and need to be rebuilt, it's probably typical hesitation and stalling from these old jet skis after they have sat still for a season or two and the carbs have gummed up. However, just before buying the carb rebuild kits, I decided to buy a compression tester and check where it was at. The MAG cylinder has 150 PSI and the PTO cylinder has 90 PSI of compression. Well there is my problem. Low compression on PTO cylinder.
What do I do now? I never had to deal with something like this on a 2 stroke engine before, and I'm new to the seadoo world.
		 Good Luck !!
  Good Luck !!
