D dennis515 New Member Jul 17, 2009 #1 the hose covring my driveshaft spins. What do I have to do to fix this problem? thanks dennis515
Chester Premium Member Premium Member Jul 18, 2009 #2 You will have to remove the pump & driveshaft and install a replacement through hull fitting. Then replace the bearing and seals in the bearing carrier. Chester
D dennis515 New Member Jul 18, 2009 #3 spinning hose on driveshaft Chester Could you be a little more specific. Concerning ther bearing and seal replacement? thanks dennis
Chester Premium Member Premium Member Jul 19, 2009 #4 That hose on the driveshaft holds a bearing carrier. You will have to replace the bearing and seals in it. Chester
K kass727 New Member Jul 21, 2009 #5 what year and model do you have, i just replaced my driveshaft and there were no bearings on mine just a carbon ring.
