I'm w/ CoastieJoe; I'd demand specifics on voltage and resistance checks on the stator circuit; it's a Delta would stator. Resistance checks are easy. What is the battery voltage with the engine off? I'll bet you have a regulator problem. Here's a cut and paste from the manual; the check of the stator is at the end. Hope this helps.
CHARGING SYSTEM 0
GENERAL
Magneto
The purpose of the charging system is to keep the
battery at a full state of charge.
The magneto is the primary source of electrical
energy. It transforms magnetic field into electric
current (AC).
4-TEC Engines
The magneto has a 3 phase, delta wound stator
on 18 poles. Capacity is 380 watts.
Rectifier/Regulator
All
The rectifier receives AC current from the magneto
and transforms it into direct current (DC).
The regulator, included in the same unit, limits
voltage at a maximum level (14.5 to 14.8 volts) to
prevent any damage to components.
The unit is using a 3 phase in series rectifier/regulator
which transforms (AC) from the magneto into (DC) to
allow battery charging.
Battery
The battery is the DC source for the electric starter,
the Multi-Purpose Electronic Module and all accessories.
Fuse
If the battery is regularly discharged, check fuse
condition.
The rectifier/regulator could be the culprit of a blown
fuse. To check, simply disconnect the rectifier/
regulator from the circuit.
The charging system is protected by 2 fuses.
If the fuse still burns, check for a defective wire.
CAUTION: Do not use a higher rated fuse as this
could cause severe damage.
4-TEC Engines
The charging system is protected by 1 fuse (30 A)
in starter relay.
TESTING PROCEDURE
NOTE: First, ensure that battery is in good condition
prior to performing the following tests.
Rectifier/Regulator
STATIC TEST: CONTINUITY
Due to internal circuitry, there is no static test available.
DYNAMIC TEST
Current Test
Proceed as follows:
– Start engine.
– Lay an inductive ammeter on positive cable of
battery.
– Bring engine to approximately 6000 RPM.
Current reading should be approximately 5 amperes,
depending on battery state. If not, check magneto
output prior to concluding that rectifier is faulty.
Voltage Test
All Models
Proceed as follows:
– Start engine.
– Connect a multimeter to battery posts. Set multimeter
to Vdc scale.
– Bring engine to approximately 5500 RPM.
If multimeter reads over 15 volts, regulator is defective.
Replace it.
NOTE: If it is continually necessary to add distilled
water to the battery, this indicates an over voltage
situation, requiring replacement of the rectifier/
regulator. If, on the other hand, the battery will not
stay charged, the problem can be any of the charging
circuit components. If these all check good,
you would be accurate in assuming the problem
to be in the rectifier/regulator.
Stator
1. Disconnect the magneto wiring harness connector.
2. Install the 6-pin magneto harness adapter (P/N
295 000 136).
NOTE: On 4-TEC engines disconnect the stator
wiring harness connector and probe the three connectors.
3. Check resistance between two of the YELLOW
wires. The resistance should be between 0.1 to
1.0 ohm.
1. Multimeter
2. Magneto harness adapter
3. YELLOW wires
4. Place either meter lead into the remaining YELLOW
wire and note the resistance (same as
step no. 3). If the readings are out of specification,
the stator will need to be replaced.
