I am having no luck removing this bastard off the crank
This is a 951 DI motor
I tried heat, 2 jaw puller, 3 jaw puller
It won’t budge.
Any advice out there?
Three jaw puller. Make sure you are pulling straight. (. All 3 legs parallel to flywheel )
Put tension on puller, then hit the puller screw with a good sized hammer.
Use caution puller and flywheel May pop off and travel
