pop off? dont know what that is, but one thing he did told me to do and i did it upon manual instructions was adjusting the low speed screw on each carb. Yea i took the baffle out to clean the gas tank, baffle looked good and clean.
I will check for compression now, if i can get the sprak plugs out, someone put some good ole elbow grease and they are tight.
Well this is the story, when i got it the guy said the motor had been rebuild, that same day i test run it with my brother and it ran fine, but when you gave it a lot of gas it would go for about 30-40 seconds full throtle then it would stop, but the engine still running, you would give it some gas and then it would stall and die. So i told my friend and he said the carbs need be clean, i took the carbs apart and gave them to him, he cleaned them and put a new OEM seals kit. Since it had the old grey hoses i changed those myself, so i figure now with new hoses and cleaned carbs it should start right up, but no, it does crank like i said but only 2 times it stayed running for 30secs and shut off, smoke came off the back as usual.
