mejim707
I took my RV cover off to inspect the clearance. Clearance is perfect. However the lower left-hand bolt the threads in the block or mostly stripped. I didn’t do it it was from the previous owner. Plus they had bolts in there that were too short by about a 1/8 - 1/4 inch. It was barely holding the cover on.
I got a perfect clearance of .0125. Went to reinstall the cover in the lower left-hand bolt doesn’t want to take torque up to 15 pounds. I can get it torqued down to about 12 1/2 pounds maybe 13 but that’s it. I know they ask for 15.
I reinstalled all of the bolts in a crisscross pattern. All other 3 bolts are perfect and torqued down to 15 pounds. It’s just that one that’s at 12 1/2 pounds and that’s all I can get it too. I took the Lockwasher off to gain access to the deeper threads. Making sure not to go too deep and penetrate the block.
I put blue Loctite 242 on the threads generously. Do you think this will be fine for the season? I don’t see any gaps around the cover everything seems to be secured perfectly it’s just that one bolt that’s at 15 pounds.
I was thinking about replacing the engine during the winter anyway. But I’m just wondering if I have to tap this hole and oversize it or should I be ok at 12 1/2 pounds on that 1 bolt?
