I just bought a 1989 Seadoo SP. I rebuilt the carb and fixed some issues with the fuel pump. I adjusted the oil injection per the manual. I know nothing about jet skis but I have worked on 2 and 4 strokes for many years. The jet ski cranks and runs fine. Here is the problem: the idle was way too high. While lowering the idle the water pump started to vibrate. It only vibrates at low rpm. I have not put the ski in the water yet. I was told by the guy that I bought it from that this was normal. He said that most older jet skis vibrate when not in the water. Is this true? Also, how long can I run the motor while hooked to a garden hose? Is it possible that the pump bearings are bad?
