94pattyspride
So I purchased a vacuum pump to suck the oil out and it is on the way. I'm a little fuzzy on the injector oil system. I see a supply (after the filter) and return line to the injection oil tank that still has oil in it. These two go to each side of the engine on the bottom. Does this oil get circulated through the crank? Should I suck the oil out of those lines? Then there is a hose going to the oil injection pump. Any advise would be appreciated. I read in the shop manual about bleeding the system. Once all oil is removed and fresh added, I'm assuming that I should bleed it??
