haydenkirk93
just bought a gtx -di bombaider 950cc 2 stroke (135hr).. im very new to the water seen, so forgive me if i ask or do some amateur things.
so top speed on this thing is only 32mph but ive seen on forums that stock they should at least be hitting 50mph, first i thought that it was either the wear ring or the impeller but after close inspection there are no dings on the impeller and the gap between the wear ring is only paper width... changed out the spark plugs and that didnt do anything... im running regular gas in it, as thats what the manual said... but ive read online its best to run mid grade so ive emptyed the tank and filled it back up with mid grade.. since then ive pulled the anchor out the front to try and get tho nose up a little more... i havent took it out again since the anchor has been removed and gas switched.. but im pretty sure those 2 little things are not going to knock 20 mph off of my top speed... any ideas guys?!?! thanks
