Here is a good source for many things relating to seadoos, but in particular this one has all the factory carb settings listed for all carburated seadoos.
Sea Doo PWC Carburetor Reference
try to stay positive about the situation. These things are 20+ years old and you will have to spend a lot of time fooling with them. I bought my first seadoo in winter thinking id have it ready for summer and went clear through to the next winter before I had the thing ready to hit the water. The good news is that by the time you have the thing water ready you will know a lot about them and as you will likely have the thing beached and your tool set out trying to figure some new and irritating problem out at some point, you will be glad you had to learn the things you did
I doubt the starter stayed engaged
its more likely that you have some sort of parasitic draw or your stator isn't doing its job.
would it have started if the battery was full?
Sidenote: if you have not already, you should seriously consider installing aftermarket bilge pump. in situations like the one you spoke of (having to float for an extended period with the motor off), your ski is most likely going to start filling in with water.
That’s normal. What’s your compression at? If you haven’t addressed that you will need to soon.
Yes....I've been told this before. Seems to run OK (for this Summer). Looks like I have a Winter project. Trying to keep costs down, so any recommendations would be helpful. I assume cylinder boring and new pistons & rings.You have something mechanically wrong with the low cylinder. You should not have that much difference in compression between them.
