fearthisinc
so i was looking the boat over to see where i could add some speakers and wanted to check behind the navigational lights to see what was behind them.. i went to the port side front nav light and noticed that it didnt look like it was screwed in all the way as one side was flat against the boat and the other side of the trim had a small gap.. so i undid the trim and saw what i needed to see but when i went to line up the screw i noticed that it looked like there were two holes for the same screw almost.. basically looked like someone started making another hole right against the actual hole.. i didnt think much of it until i was putting the trim back on and and noticed that the screw wasnt getting tiight at all.. i took it out and now the hole is bigger then the screw and obviously now it wont tighten.. is there any wayy to fix this?? or do i just have to get a bigger screw.. i mean i know if i cut the speakers in i could probably throw a nut on the back but until then its just hanging there and i know that cant be good for the remaining screw thats in there.. any ideas???
