68ragtop
Hi guys! Thanks to many of you that have been helping me out with my 2002 GTX 4-tec project. I am happy to say, the ski is done & running. I had it out on the water Sunday. The machine runs nice, but is having what I would call a pre-ignition problem on restarts when it is up to operating temperature. Cold & warm starts is fine, but after a few passes on the water, the engine bucks the starter on the compression stroke. Is this at all common with 4tecs? I am not sure how old the gas is, as the tank was full & I was told it was on the water this spring. So it could be fuel from last season. Battery is new, & passes tests. I did try another good battery to confirm that wasn't my issue. From what I see in the service manual, it would appear everything is control by the computer, & is non adjustible. I suppose the engine could be running hot? But again, nothing is shown on the info screen to indicate that.
From here, The only thing I can think to try is to drain & replace the fuel with non-ethonal 92, & maybe drop the plug temps from 8's to 9's to see if lowering the combustion temperatures helps at all.
Nothing out of the norm displayed on the info center, codes or otherwise.
Any thoughts?
Any thoughts?
