JJinSC
Ok, these issues just keep alluding me. Everything runs fine except for 1) slight bog from idle. It will clear out and not die on its on now that I have confirmed the a-pump nozzles are both spraying. It just hesitates now and then clears and goes. 2) hard restart after sitting for 15 minutes to a couple of hours. It was almost impossible to restart but I found that the pressure relief valve was not working properly. Cleaned it and got it working correctly and now I can restart it after sitting for 15 minutes to a couple hours but I have to keep blipping the choke. If I pull the choke and hold it too long it will die. I have to pull the choke and immediately release it about every two seconds to keep it running. After about a minute of doing that I can start giving throttle and as soon as it starts to bog and die if I blip the choke really fast it will grab and go. Once it goes it clears and runs fine.
Other than these two issues it runs perfect. Cold it will fire up immediately and run. Idles perfect. Has that slight hesitation off of idle but then runs perfect at all other RPMs. I am completely at a lost now what else to try. All lines replaced. New fuel selector valve. Vents working correctly. Carbs rebuilt twice. RAVEs in perfect working order. Water regular checked today. It seems fine.
Anyone have any other ideas?
