ALFONZO PINEDA
New to site. Enjoying it very much, thank you for all you do. I recently purchased two running seadoos that came with a third non-running ski. Currently I have a pretty long list of maintenance i have learned, from reading threads on this site, my running skies need. Since i am new to working on jetskis, i figured i would use the broken ski as my guinea pig this winter to help me get some practice before working on the others come spring. I have checked the compression on the engine, the guage worked fine when checking the working skies, and it showed to be 30 psi. (Is that even possible or am i doing something wrong.) I have already pulled exhaust system and am going to pull and go through carb. today. I also plan on pulling jet pump and engine. I like getting my hands dirty and am doing it mostly for practice, however i would like to get it running if possible.
Is it possible to have that low compression and still save the engine?
Should i pull the top off engine first and check it or just pull the whole thing?
Are any of the parts interchangable with my other skies if i can't fix this one?
Sorry if i'm rambling or asking to much in one thread but i am chomping at the bit to get started. Thank you in advance for your help.
