95 Seadoo SPX with 657x
pbob42
Pull this out and running ruff this year. Closed down last fall. Starting a little ruff, transition to high speed a little tuff. Wants about half choke to fire up. Get to full speed and RPMS start bounding from 100% to 70% in 2 second cycles. Probably got up to about 30.
Figured, clean out the carbs and I'd be in business. Got to taking of the #6 allen heads holding the carb on and they are locked up. I am certain I will strip those heads out before they loosen up.
It there any magic pixie dust or juice I can run through these carbs before I have to pull this motor and yank that manifold off?
thanks
Soak with PB Blaster. Very very carefully heat the manifold with a propane torch and try removing the bolts.
