GTX1994 crank main journal
drjones_xxx
Hi guys just stripped down a white 650 after bigend bearing on mag side has destroyed its self, is it possible the crank has been assembled badly as i have just realised its been rebuilt before for PTO bearing issue of the same. The main journal seems to be in wrong place and is tight against the next oil seal and bearing and is very very stiff to turn. Is this correct as logic tells me Not and how do i move the journal over.
Question 2 How do you split the balance weights to get out the bigend bearings?
Uploaded some pics of the problem if that helps
many thanks
Daz
