Hello! i just bought my first sea doo. It's a gsx limited 1998.
i have problem running it around 3/8 throttle(3600rpm). It seems lean. i have searched the forum and found alot of help regarding this, but i find it strange that i can make the craft run perfectly by ''compensate'' with the choke.
Does anyone have the same problem? I am worried i will destroy the engine(?)
i pulled out the carbs and cleaned them and changed filter diaghram and sealing.
tried the low speed adjuster, but now i only reach around 4000rpm.
I have not tested the pop off or compression. previous owner changed the pistons last summer.
After running it for 15min the engine seems cold..? No problem to touch the cylinder or exhaust pipe.
Hope someone can help me. Sorry for the bad writing, but im from Norway.
