I also told you a hairline crack in your block will cause your engine to lean out
Mixture screw is set at : Low Speed – 1 1/2 +/- 1/4...
I saw your video that's exactly how mine was running . And it was fuel valve the one that you turn on and off and on reserve. But you already eliminated that problem right
Try setting the low speed screws to 1 3/4 turns.
Chester
Might consider buying a used carb and install. I did it with my problem child Ski 13. It fixed the problem. CoastieJoe can tell you. I went over and over Ski 13. Are you sure it is a carb / fuel problem? Could need spark plug wires trimmed or have a connection problem somewhere. Was carb cleaned right and all wear parts replaced? JETS REPLACED? Pulled the jets and cleaned passages? Might need the, not normally replaced gaskets, replaced. Running the same after warm, kinda says it's one of these issues.
Yes i assume! Pulled it out and cleaned it with diesel and then used compressed air. But the valve is "sealed" so i couldnt inspect the inside of it.
Can i try to bypass that too ?
