GS no spark help
COLT45
I have a 2001 GS, took it out yesterday and after 10 feet it died, checked and there is no spark. I got new plugs, check all fuses which were good, checked wire plugs and grounds, Where do I start to see whats wrong?
thanks
I checked the box and its dry, all contections are tight, fuse is good. is there a way to test the coil ?
thanks
light test, the white wire at the coil, wire cranking motor over. If it dont light up, then either a mpem issue or stator issue.
