Getting water in intake during flushing
No..non s/c. Did correctly startup procedure on water hose. Have air intake snorkel off and see water coming thru small hose at near oil cap assembly.. coolant level normal, compression good 160 psi.. no leakage on leak down..oil xhanged/ normal level. New plugs. Good spark. Does run off idle (dies) @ idle. No codes stored..guages are inop but try know good cluster..does seem to push more water thru as u accel/ gets hotter. Anyone see this?
yep that is correct, do you have a pic of the hose that you say is leaking water?
So while flushing water come out from that hose? That's connected to the vent valve which is bolted to the head. No liquid flows thru that hose. I suspect a problem with your head. Is the oil milky at all? Have you run it in the water with that hose disconnected to see if water is coming out?
