Looking for location of voltage regulator on 2002 gtx 4 tec. I’m getting the low 12volt warning. Swapped battery to check and had same result. Location doesn’t show up in service manual from what I can find.
Open the front hood and remove the panel under the steering column, the rectifier/regulator is located on the right side (as if sitting on the ski) above the fuel tank.
